MattA
6cyl dash cluster
Hi am after a 6cyl dash cluster prefer km/h but not fussed just needs to work.
cheers Matt
Me gots one, VDO. Will need your own needles.
You know the only difference is the white plug on the front, if you've got your old one still. Means you can use any cluster. The front plugin determines 4 or 6 cylinder for rev counter I think.
cheers Matt
should have some , what model/year of car ...
How much?
It's for '87 325 mine has a gremlin only ever seems to happen when I need a WOF. Was unaware that they are interchangable between 4 - 6 cyl, thanks
cheers matt
How much?
cheers matt
$65 for my VDO one.
$40
All MODELS avaliable
ph.0212435526
Ray
Thanks, sorted.
cheers Matt
