Surge
M20B25 Engine
M20B25 Engine, Out of a 1986 325i (Was running fine upon removal)
200+ KM's (Can't remember exact Km's, was in the low 200's) - Car it was out of took a hit to the rear quarter/side.
Can supply a manual Getrag 240 (off a 320i) to suit.
Selling complete engine + computer.
$700 ono.
$700 ono.
well, i might be keen, but with those k's, and age, no gearbox, no loom or ecu the price has to be dropped, and then it's subject to inspection. was cold compression tested ? is it still in the car ?
where's the engine ?
The price includes Loom, Ecu etc (Aside from radiator) It's in a car - facelift 320i, Was going to go all the way through with the conversion but got too lazy to finish.
Haven't compression tested - can be done though - the engine cranks (haven't hooked up fuel etc...) just ignition.
Gearbox can be supplied for an additional sum.
Location Christchurch.
free shipping to auckland?
Go halves on the airfare, I'll take it as hand luggage. :)
I would happily go halves on frieght. (It's not too much from memory anyway - $140 odd..)
Bump'n'Grind, $600 Ono. Need to get rid of!
is it a high compression one or low compressions one ? (9.7:1 vs 8.8:1) ?
where are you located ?
Is there any way to tell which is high and which is low? I'm in CHCH
-james
pre FL or FL? 8.8 will only be imported FL 325i's...NZ new ones had 9.7
Pre-FL engine.
Currently pending an offer 320guy but may have a conversion up for sale later.
Ok, Engine must go - $550.. Will take no less, I'll just build up something out of it if need be!
Still have a FL body (all panels) - 325i Running gear (larger struts etc..) Headlights, Grills, the whole shabang... PM offers on anything.
