Surge 1 Report post Posted May 7, 2007 M20B25 Engine, Out of a 1986 325i (Was running fine upon removal) 200+ KM's (Can't remember exact Km's, was in the low 200's) - Car it was out of took a hit to the rear quarter/side. Can supply a manual Getrag 240 (off a 320i) to suit. Selling complete engine + computer. $700 ono. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 7, 2007 Does it have a 5yr, 200,00k warranty ?? Quote Share this post Link to post Share on other sites
mops 4 Report post Posted May 7, 2007 Surge said: M20B25 Engine, Out of a 1986 325i (Was running fine upon removal) 200+ KM's (Can't remember exact Km's, was in the low 200's) - Car it was out of took a hit to the rear quarter/side. Can supply a manual Getrag 240 (off a 320i) to suit. Selling complete engine + computer. $700 ono. well, i might be keen, but with those k's, and age, no gearbox, no loom or ecu the price has to be dropped, and then it's subject to inspection. was cold compression tested ? is it still in the car ? where's the engine ? Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted May 7, 2007 The price includes Loom, Ecu etc (Aside from radiator) It's in a car - facelift 320i, Was going to go all the way through with the conversion but got too lazy to finish. Haven't compression tested - can be done though - the engine cranks (haven't hooked up fuel etc...) just ignition. Gearbox can be supplied for an additional sum. Location Christchurch. Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted May 7, 2007 free shipping to auckland? Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted May 7, 2007 Go halves on the airfare, I'll take it as hand luggage. I would happily go halves on frieght. (It's not too much from memory anyway - $140 odd..) Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted May 9, 2007 Will be going on trademe later this week. Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted June 18, 2007 Bump'n'Grind, $600 Ono. Need to get rid of! Quote Share this post Link to post Share on other sites
mops 4 Report post Posted June 18, 2007 Surge said: Bump'n'Grind, $600 Ono. Need to get rid of! is it a high compression one or low compressions one ? (9.7:1 vs 8.8:1) ? where are you located ? Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted June 20, 2007 mops said: is it a high compression one or low compressions one ? (9.7:1 vs 8.8:1) ? where are you located ? Is there any way to tell which is high and which is low? I'm in CHCH -james Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted June 20, 2007 pre FL or FL? 8.8 will only be imported FL 325i's...NZ new ones had 9.7 Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted June 20, 2007 Are you keen to sell the gearbox including all parts to do a manual conversion? Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted June 20, 2007 Pre-FL engine. Currently pending an offer 320guy but may have a conversion up for sale later. Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted July 2, 2007 Ok, Engine must go - $550.. Will take no less, I'll just build up something out of it if need be! Still have a FL body (all panels) - 325i Running gear (larger struts etc..) Headlights, Grills, the whole shabang... PM offers on anything. Quote Share this post Link to post Share on other sites
