*Glenn* 856 Report post Posted May 20, 2007 Any one got one ??? I've also got a small case 4.44:1 and I'll have the 3.91:1 for sale too if I can get a good 3.64 Cheers Glenn Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 24, 2007 Any one got one ??? I've also got a small case 4.44:1 and I'll have the 3.91:1 for sale too if I can get a good 3.64 Cheers Glenn Come on guys......someone must have one ?? Quote Share this post Link to post Share on other sites
will 169 Report post Posted May 24, 2007 I have medium case Glenn, nothing small. Will Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 24, 2007 I have medium case Glenn, nothing small. Will Thanks Will... but that wont work....cant swap the 318 TI axles into it. Circlip and seal positions are wrong and TI's run smaller CV joints on the axles. You can swap them around in E30's because the flange spacings and bolt sizes are the same. 318 TI's are different.....we tried today Quote Share this post Link to post Share on other sites
will 169 Report post Posted May 24, 2007 I have not ever seen a small case 3.64 Glenn, so good luck. Have to be 3.64? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 28, 2007 I have not ever seen a small case 3.64 Glenn, so good luck. Have to be 3.64? I might have a 3.64 e21 open diff. I believe the ring and pinion can be swapped from that to a small case e30 diff. I need to check on whether I actually have the 3.64 - I've forgotten exactly what I've got, and can't remember if I swapped the 3.64 for a 3.91 or if I still have both. Either way I've definitely got a 3.64 e21 LSD, but I'd want $$$ for that. PM me with a serious offer for the LSD if that's what you want, and I'll post back here if I can find the 3.64 non LSD. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 28, 2007 I might have a 3.64 e21 open diff. I believe the ring and pinion can be swapped from that to a small case e30 diff. I need to check on whether I actually have the 3.64 - I've forgotten exactly what I've got, and can't remember if I swapped the 3.64 for a 3.91 or if I still have both. Either way I've definitely got a 3.64 e21 LSD, but I'd want $$$ for that. PM me with a serious offer for the LSD if that's what you want, and I'll post back here if I can find the 3.64 non LSD. OK, I've checked and it seems there is no 3.64 (I must have swapped it) and the "3.91" might actually be a 4.1 (which would explain why I hit the limited in 4th just after the kink at Puke). I definitely have an e21 3.64 LSD though, as above. Quote Share this post Link to post Share on other sites
HELLBM 1663 Report post Posted May 28, 2007 3.64 small case came in the 4 speed manual 316/318 E30`s. Rare but avaliable. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 30, 2007 I dismantled a while ago an 88 320 auto (pre facelift NZ new) which had a 3.64 small open in it, appeared to be factory too, sorry dont still have though. Quote Share this post Link to post Share on other sites
mark205 0 Report post Posted June 6, 2007 Any one got one ??? I've also got a small case 4.44:1 and I'll have the 3.91:1 for sale too if I can get a good 3.64 Cheers Glenn the tag on my diff says 3.45 if thats any help. Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted June 7, 2007 Ive got one out of a early 316 m10 monster, but the spider gears have been welded and then the weld has broken, crown wheel and pinion are still fine though, cracked rear cover also - can be fixed, will part exchange for a good 3.91 med case open if you know of one. Quote Share this post Link to post Share on other sites
