jjs 60 Report post Posted May 27, 2007 Is there a reason why the time noted on forum posts is two hours too fast? Is there something wrong with my computer, or do you folks in the North run two hours ahead? Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted May 27, 2007 Is there a reason why the time noted on forum posts is two hours too fast? Is there something wrong with my computer, or do you folks in the North run two hours ahead? WOW I finally fixed this!! the board time should now be bang on, if you are an hour out change your time and date settings to allow for daylight savings. Cheers, Ollie Quote Share this post Link to post Share on other sites
B*Emz 0 Report post Posted May 27, 2007 WOW I finally fixed this!! the board time should now be bang on, if you are an hour out change your time and date settings to allow for daylight savings. Cheers, Ollie Hollerrr!! Quote Share this post Link to post Share on other sites
