tibbs.james 1 Report post Posted July 2, 2007 As the title says I am getting a grinding noise while im turning hard to the left like you would while in a carpark, it does not do this while steering to the other side. My dad seems to think it could be a wheel bearing or a ball joint that is causing the problem but i don't see how that could be happening. Any advice would be well appreciated Car is a 1990 E30 Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted July 2, 2007 Perhaps it is coming from the back of the car - CV joint? Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted July 2, 2007 Do you have stock rims/tyres? It is possible that the steering geometry one way is causing something to hit that doesn't happen the other. Emma experienced this running her under-spaced 17's and before I got my alignment done after bending the rims I had a tyre rubbing on the chassis rail on one side only at full lock. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted July 2, 2007 I am Running stock 14" weaves with 195/65/14 rubber, but i am due for an alignment as its pulling a bit left and has been for some time. i might take the wheel off tonight and see if i can see any rubbing on the tire or chassis. Quote Share this post Link to post Share on other sites
