rowanhol 0 Report post Posted July 23, 2007 hey guys i have a 535 manual and a 525m50 auto parts car, just wondering if it's worth ripping the diff out of the 525 as a spare for the 535? am i correct in thinking the m50 is higher revving so will have a better accellerating diff (shorter ratio is it?) but its auto so will that make it have a taller diff than a manual 525? if so will it be about the same ratio as the 535 manual? am i confusing you guys? someone shed some light please Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted July 24, 2007 just check the tags on the diff . also make sure its a large case diff . should have 8 bolts around the output shafts flanges. a 3.64 is a good ratio Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 25, 2007 hey guys i have a 535 manual and a 525m50 auto parts car, just wondering if it's worth ripping the diff out of the 525 as a spare for the 535? am i correct in thinking the m50 is higher revving so will have a better accellerating diff (shorter ratio is it?) but its auto so will that make it have a taller diff than a manual 525? if so will it be about the same ratio as the 535 manual? am i confusing you guys? someone shed some light please The diffs all have a ratio tag on them. Check the ratio. Its a small tag on one of the rear cover bolts. Compare ratios The first 3 numbers are the ratio...ie: 444 = 4.44:1 364 = 3.64:1 Hope that helps Glenn Quote Share this post Link to post Share on other sites
