Munts316i
revs
my 316 comes without a tacho (has a clock in its place) so the old owner put a cheap one in, the car goes fine, but it doesnt really rev...at all, according to the tacho. currently i can do 70ks in 4th at 2 grand, but the car really doesnt like to rev, it only comfortably goes to 4. is the setting wrong?or do 316's just not rev?
My M10 318 is the same. I don't bother going over 4000, as it doesn't sound too well (bloody 4cyl) and doesn't pull all that smooth above 4k.
Edited by E30_318i
get a honda.
9k redline :D
Guest Speedye30
Haha! You asked for it... Inline 6 is by far the best engine configuration, at least after v12... Anyone disagree??
no disagreement here.
70k's in fourth? ofcourse you were doing 2k rpm you'd barely be doing 5k in second gear.
by 70ks in 4th at 2k, i was meaning that it revs normally, just doesnt go high, at all and after my old car its a fair difference, ive never driven a 4 cylinder that rev'd so low and just wanted to know if it was normal.
I suspect that the Tacho is reading wrong, can you get it checked and callibrated anywhere?
I'm pretty sure that your 316i should rev to a fair bit higher than 4,000 rpm's
Here are the specs for the E30 316i
Engine Data
Displacement 1596 cm3
Number of Cylinders 4
Max Power 102 bhp (75 kW) 5800 rpm
Max Torque 140 Nm (103 1b.ft) 4500 rpm
Compression Ratio 8.2:1
Firing Order 1 - 3 - 4 - 2
Oil pressure - at Idle 0.5 to 2.0 Bars
Oil pressure - running > 4 Bars
Valve Clearances Hydraulic Adjusters
Idle speed 800 +/- 40 rpm
CO% at 3000 rpm 0.7 +/- 0.5
Spark plug gap 0.8 mm
Spark plug type Bosch W8 DC
Capacities
Fuel Tank 64 Litres (14.1 gal)
Engine Oil 4.0 Litres
Cooling System 7.0 Litres
Manual transmission - ZF 1.2 Litres
Manual transmission - Getrag 1.0 to 1.5 Litres
Final drive 0.9 Litres
Misc.
Accelerator cable free play 1.0 mm
Min. rotor thickness (ventilated) - front 20 mm
Min. rotor thickness (solid) - front 10.7 mm
Min. rotor thickness - rear 8.0 mm
Handbrake shoe minimum thickness 1.5 mm
Handbrake lever travel 5 to 8 clicks
