kakarott 0 Report post Posted August 25, 2007 hi guys, will X5 wheels (18 X 8.5) fit on a E46? the Stud Patterns should be same, but not sure about offset. Cheers Nick Quote Share this post Link to post Share on other sites
nath 174 Report post Posted August 25, 2007 Not sure about E46, but i know they fit on E34, perhaps E46 has same offset? Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted August 25, 2007 x5 wheels fit e36's, so should be ok for e46's Quote Share this post Link to post Share on other sites
kakarott 0 Report post Posted August 26, 2007 thanks for the replies should be fit if the wheels fit e34's and e36's Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted August 27, 2007 for an e46 rear max offset is 39 at 9.5 front max offset is 39 at 8.5 I think they are 40 offset, so youll be fine. Quote Share this post Link to post Share on other sites
kakarott 0 Report post Posted August 27, 2007 for an e46 rear max offset is 39 at 9.5 front max offset is 39 at 8.5 I think they are 40 offset, so youll be fine. that will be very helpful, thanks Quote Share this post Link to post Share on other sites
kakarott 0 Report post Posted September 7, 2007 hi guys, i just went to bmw dealer yesterday, i was told that the offset of x5 wheels are way to high for an e46! what do you guys think? Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted September 7, 2007 When i eqnuired a while ago thats what they said also. Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted September 7, 2007 hi guys, i just went to bmw dealer yesterday, i was told that the offset of x5 wheels are way to high for an e46! what do you guys think? Do you know what year vehicle the X5 wheels are off? From memory the factory ET for the 18" X5 wheels are 48 which is very high. I think even though the offsets of the wheels are very similar between an E46 and an X5, the width of the X5 wheel will cause you problems and hit the inside struts at the front, they should bolt onto the rear no problems though. Quote Share this post Link to post Share on other sites
