joel 0 Report post Posted October 3, 2007 F***en pissed to find that my headlight is smashed on my E30. Kept in a garage and driven once or twice a week so have no idea how but guessing it was a stone. Can I just replace the lense or do I have to replace the whole light? It will be a pain if I do because it is a smiley! Cheers, Nick Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 3, 2007 Happened to me once too - now I have clear headlight film on all my lights. Possible to change lens if you have the skills, but finding a lens is as hard as finding the whole light and then you have to fit it. Buy a new light and fit it in about 5 mins. Quote Share this post Link to post Share on other sites
joel 0 Report post Posted October 3, 2007 Happened to me once too - now I have clear headlight film on all my lights. Possible to change lens if you have the skills, but finding a lens is as hard as finding the whole light and then you have to fit it. Buy a new light and fit it in about 5 mins. Ohk how much would that cost? Cheers Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 3, 2007 dunno - ring up the $tealer - that should give you a nice heart attack when they tell you. Then go on trademe or ring someone like Ray at HellBM. Quote Share this post Link to post Share on other sites
joel 0 Report post Posted October 3, 2007 So can I take the smiley part out and put it in a new headlight? Sorry about all the questions. Thanks alot, Nick Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 3, 2007 (edited) You take out the whole low beam lamp. Remove the wire connectors for both high and low beam, and park light. Remove grill (a couple of clips and 2 screws). Remove headlight assembly - (4 large phillips head screws.) and pull out headlight assembly. Pop broken lamp carefully off the adjuster stalks to avoid breaking the clips. Install new lamp in reverse order. 10-15 mins tops even if you've never done it before. Beware - lamps are different left and right so make sure you buy the correct lamp. Onlyother possible obstacle is the self-levelling headlamps some cars came with with the in-car control. Have to disconnect it aswell. Mine doesn't work so I just removed it. Edited October 3, 2007 by bravo Quote Share this post Link to post Share on other sites
Guest 540Si Report post Posted October 3, 2007 Pop broken lamp carefully off the adjuster stalks to avoid breaking the clips. Hey Nick I had to replace a low beam in my 535 a few weeks back and what Bravo says about being careful about adjuster stalk clips is probably the key. I carefully poked them back thru the holes with a small flat screwdriver - there's probably an easier way mind you! Si Quote Share this post Link to post Share on other sites
HELLBM 1687 Report post Posted October 4, 2007 Pm`d Regards ray 0212HELLBM Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 4, 2007 You take out the whole low beam lamp. Remove the wire connectors for both high and low beam, and park light. Remove grill (a couple of clips and 2 screws). Remove headlight assembly - (4 large phillips head screws.) and pull out headlight assembly. Pop broken lamp carefully off the adjuster stalks to avoid breaking the clips. Install new lamp in reverse order. 10-15 mins tops even if you've never done it before. Beware - lamps are different left and right so make sure you buy the correct lamp. Onlyother possible obstacle is the self-levelling headlamps some cars came with with the in-car control. Have to disconnect it aswell. Mine doesn't work so I just removed it. Only 3 large Phillips Head screws last time I looked Graham? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 4, 2007 (edited) hah. I was counting in my head and was thinking -two??? no, more than that. must be four - that doesn't sound right??? oh well... So three was the number I was looking for. Thankyou David. Edited October 4, 2007 by bravo Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted October 4, 2007 Damn look at all those stone chips! no wonder its broken, a shame its a smiley too Quote Share this post Link to post Share on other sites
joel 0 Report post Posted October 4, 2007 (edited) Yeh I know, thats the problem with black, shows the stonechips hard out! Edited October 4, 2007 by GIJoel Quote Share this post Link to post Share on other sites
