steve R 0 Report post Posted October 15, 2007 Can any one recommend and good shop in Auckland where I can get my wheel offset rest slightly? Quote Share this post Link to post Share on other sites
Guest Rick James Report post Posted October 15, 2007 You can get alloys ground down to provide a higher offset, but not the other way around. Try arrow wheels, or Josh will recommend a place on the shore. Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted October 15, 2007 You can get alloys ground down to provide a higher offset, but not the other way around. Try arrow wheels, or Josh will recommend a place on the shore. thats what im after thanks Quote Share this post Link to post Share on other sites
hybrid 1039 Report post Posted October 15, 2007 Brugar engineering is another place. Expect some lead time however. Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted October 15, 2007 Brugar engineering is another place. Expect some lead time however. where are they located? Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted October 15, 2007 GR engineering do all that kinda stuff.Got my old wheels fiddled with by them and did a good job. Quote Share this post Link to post Share on other sites
hybrid 1039 Report post Posted October 15, 2007 http://www.brugar.co.nz/ Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted October 17, 2007 thats what im after thanks just be careful that is enough 'meat' left between the back of the wheel and the bottom of the stud hole. It has to be a minimum of 6mm from memory, any less and it can weaken the wheel and lead to all sorts of problems (ie wheel falling off), then the real shennanigans begins when the SCU determines what the cause was.... lawsuits etc etc etc Quote Share this post Link to post Share on other sites
