E30-OLLIE 0 Report post Posted October 17, 2007 Hi, I'm needing a loom to plug into a M20B25 ECU, doesn't matter if it's been cut as long as the wires aren't too short to do anything with. I have a 2.5 engine running off a 2.0 computer and obviously ain't doing the trick cheers. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted October 18, 2007 for the trouble your going to have splicing all those wires i would just go motronic. get a new loom with computer to mach. much easyer and will work better. talk to ray 0212hellbm he will sort u out Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted October 18, 2007 Hi, I'm needing a loom to plug into a M20B25 ECU, doesn't matter if it's been cut as long as the wires aren't too short to do anything with. I have a 2.5 engine running off a 2.0 computer and obviously ain't doing the trick cheers. haVE A 2L F/L CAR I AM STRIPPING TO BITS in my garage now . is motronic . you will just need 2.5 ecu to plug into it . 021433600 Quote Share this post Link to post Share on other sites
HELLBM 1695 Report post Posted October 19, 2007 Have everything you need Regards Ray 0212HELLBM Quote Share this post Link to post Share on other sites
