hybrid
Lock bolts
Some good lock bolts for your BMW :)
Posted Image
Kit includes 2 sets of 4 wheel locks. 1 set is the same size as the stock lug studs (26.4mm) , the other set is longer (33.3mm) for use on cars with wheel spacers.
about $150 landed
other cheaper ones.
Posted Image
Protect your valuable wheels and tires against theft. Bavarian Autosport wheel locks will give you peace of mind without sacrificing your BMW's looks. Precision machined from stainless steel. Sold in sets of 4.
see on http://www.bavauto.com/shop.asp
They look good but why do they come in sets of four :wacko:
edit: I guess if ya buy 5 sets you'll have the right number for four five stud wheels anyway!
Edited by madandy
You only need one per wheel for it to not come off ;P
I've used the 2nd ones, work fine - until you loose the damn key!!!
Normally you would leave the key in the car anyway incase of a flatty, and so if you can remove the wheels normally [ie: no alarm], then whats stopping them from breaking glass and gaining the key that way? More of a deterant than anything.
Haha yeah you're right there. I must have been cafeine deficient when I made that post, lol.
From experience one lock nut is not enough though. I've seen wheels left with only the locknut remaining...crash!
They're lock bolts so you only need 1 per wheel! The other 4 will be your normal ones.
Looks like the 2nd set is for 7mm spacers which is what come with ACS wheels.
Edited by Yuen
