eef48 0 Report post Posted November 5, 2007 (edited) You know I consider myself a bit of a whizz when it comes to clocks. My step father repairs clocks.I have programed alot of time clocks over the yrs but do you think I can get the clock to adjust in my car! The manual is in Japanese so thats not a big help,but looking at the pretty pictures it seems to me that all you need to do is turn the right hand dash button to the right or left to adjust the time. The stem doesn't seem to turn either way so is there a fault with it?If I push it in it does change from12 to24 hr mode. Thanks for any help. Mr Beam Edited November 5, 2007 by Mr Beam Quote Share this post Link to post Share on other sites
westy 614 Report post Posted November 5, 2007 In ours, 2000 328, key to position 1, trip meter to clock(left hand lever), turn right button knob thing in instrument cluster left or right. All I know. Hope it helps. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted November 5, 2007 Turn the car over Press your dash mode button on the indercator arm till your clock appears. on the right hand stork (next to rev needle) push down and twist carefully clockwise and anti-clockwise to adjust ... center it and press down to go to 24hour time. Mines quite fiddley but youll get it. Quote Share this post Link to post Share on other sites
eef48 0 Report post Posted November 6, 2007 Turn the car over Press your dash mode button on the indercator arm till your clock appears. on the right hand stork (next to rev needle) push down and twist carefully clockwise and anti-clockwise to adjust ... center it and press down to go to 24hour time. Mines quite fiddley but youll get it. Quote Share this post Link to post Share on other sites
eef48 0 Report post Posted November 6, 2007 Thanks for the info. had to twist it pretty hard to get it to play ball.I thought the stem was going to snap off in my hand. Quote Share this post Link to post Share on other sites
