Eagle 1777 Report post Posted November 17, 2007 Hi Just brought my first E30(NZ '89 325i manual) which has the analog clock, was just wondering if you can drop in a full obc with out to much hassle like the E34's?. Also where abouts is the diff ratio number on the diff?, i cant seem to find any tags etc just what looks like a part number. Cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 17, 2007 Hi, should be a metal tag behind one of the back cover bolts with the ratio on it. Quote Share this post Link to post Share on other sites
bmw.maniac 1 Report post Posted November 17, 2007 Welcome, It is possible, but it is be complex. You will need the OBC itself and an extra wiring harness at the very least. Check out this for more details OBC Retrofit This pick put me off installing an OBC! Wow Do you have any pics off your car? Eddy Quote Share this post Link to post Share on other sites
HELLBM 1675 Report post Posted November 17, 2007 Not to difficult to do. I have everything that is needed. Regards Ray 0212HELLBM Quote Share this post Link to post Share on other sites
Eagle 1777 Report post Posted November 17, 2007 thanks for the replies. Here a few pics from my ph hence the quality. Quote Share this post Link to post Share on other sites
