325jones 0 Report post Posted November 21, 2007 (edited) just a bit lost on were the engine number is on my 325i e36 any ideas what side and were bouts it is? o yer itz a 1992 Edited November 22, 2007 by 325jones Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted November 21, 2007 Do you want to know what model engine or the number? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 22, 2007 (edited) The engine type will be either M50B25 or M52B25 (with Vanos)...dependant on year The engine number can be determined by the last 7 digits of the Vin number ie: ET56746 All parts for your car can be purchased by that number If you want the actual engine number ( for wot ever reason ) ring the dealer and quote that number EASY Cheers Glenn Edited November 22, 2007 by botanymotorworx Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted November 22, 2007 The engine type will be either M50B25 or M52B25 (with Vanos)...dependant on year The engine number can be determined by the last 7 digits of the Vin number ie: ET56746 All parts for your car can be purchased by that number If you want the actual engine number ( for wot ever reason ) ring the dealer and quote that number EASY Cheers Glenn I didn't think there was an M52B25 in 325s - I thought it was designated M50B52 TU or something along those lines and the M52 was only for 323 and 328? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 22, 2007 (edited) I didn't think there was an M52B25 in 325s - I thought it was designated M50B52 TU or something along those lines and the M52 was only for 323 and 328? His car would be M50B25 ( non Vanos ) or M50B25TU ( Vanos ) TU = Technical Upgrade Cheers Glenn Edited November 22, 2007 by botanymotorworx Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted November 22, 2007 His car would be M50B25 ( non Vanos ) or M50B25TU ( Vanos ) TU = Technical Upgrade Cheers Glenn WBACB32010FA72649 VIN Number A72649 So is the engine number? but on my pink slips it says egine number is 35760236 and its a cc rating of 2949cc u know were bouts the actual is is printed on the motor? thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 23, 2007 WBACB32010FA72649 VIN Number A72649 So is the engine number? but on my pink slips it says egine number is 35760236 and its a cc rating of 2949cc u know were bouts the actual is is printed on the motor? thanks FA72649 identifies your car for options and spare parts. It is not your engine number. Unless your car has been modified or had an engine swap it is not 2949cc it will be 2494cc Y do you need the specific engine number ?? Its on the block, on a machined surface just below the starter. I'll try and get it for you of the vehicle data base. Cheers Glenn Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted November 23, 2007 FA72649 identifies your car for options and spare parts. It is not your engine number. Unless your car has been modified or had an engine swap it is not 2949cc it will be 2494cc Y do you need the specific engine number ?? Its on the block, on a machined surface just below the starter. I'll try and get it for you of the vehicle data base. Cheers Glenn Thanks for the my email is jonescs23 at xnet dot co dot nz Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 23, 2007 PM me with your fax number and I'll send you all the BMW info on your car No engine number recorded tho.....which sometimes happens ( a lazy krout ) You will have to raise the car and check the area I told you about before Cheers Glenn Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 23, 2007 (edited) Here ya go Interesting isnt it ?? Edited November 23, 2007 by botanymotorworx Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 23, 2007 Here ya go Interesting isnt it ?? BuggaDidnt work...I'll fax it Thought it might be interesting for others to see Cheers Glenn Quote Share this post Link to post Share on other sites
