mark247 42 Report post Posted November 26, 2007 (edited) Hey guys, My mate and I are wanting to chip our ECU's in our e30's. We found the .bin file for a JC Chip on the internet so we already have something to base our chip off, we also have a Motronic ECU editor so we can fiddle around. I have just ordered a chip from Jaycar so i dont have to wipe over my original. All i need is a Eprom burner. So does anyone in the Hamilton / Tauranga area have a burner? Or even Auckland... We'll pay with alcohol or maybe a bit of cash. It needs to be compatiple with 27C256 chips. So, anyone got one?? Thanks a lot. Mark Edited November 26, 2007 by Mark247 Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted November 26, 2007 Gah had one at my old work! Im never in there anymore otherwise id get the file and do it for ya and make one for myself! I also had a programmer dammit! Hmmm what chip and how much i could try Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted November 27, 2007 Chip is a 27C256, $15 at jaycar. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted November 28, 2007 you should be able to have it done by an electronics specialist ? for not too much, Would you mind sharing the .bin file on this board ? Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted November 28, 2007 you should be able to have it done by an electronics specialist ? for not too much, Would you mind sharing the .bin file on this board ? Yea I'm going to go ask a few places tomorrow. I will let you know if it works and I will share the .bin file if it's all good. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted November 28, 2007 awesome turns out i cant get the burner anyway, absolute mission. if only a couple of months ago.. let us know how you get on - dyno! Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted November 28, 2007 awesome turns out i cant get the burner anyway, absolute mission. if only a couple of months ago.. let us know how you get on - dyno! Haha i dont think ill be putting it on the dyno. It is ment to add 10hp to a 325i and 5hp to a 320i, so if that 10hp is correct I think ill feel the difference. Also it's ment to add a bit of torque, but i cant recall how much. What I'll do is slam my foot to the floor to remind me how powerful ( or unpowerful ) my car is now before i put the chip in, and then ill install it and do the same thing after. haha. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted November 29, 2007 Haha i dont think ill be putting it on the dyno. It is ment to add 10hp to a 325i and 5hp to a 320i, so if that 10hp is correct I think ill feel the difference. Also it's ment to add a bit of torque, but i cant recall how much. What I'll do is slam my foot to the floor to remind me how powerful ( or unpowerful ) my car is now before i put the chip in, and then ill install it and do the same thing after. haha. Get a before and after dyno sheet, then sell the chips Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted November 30, 2007 Well i found a place who could burn my chip for me, and i got it done, cost me $20 tho. I put it in and i could notice the difference, the car was running really well. I took a plug out to check to see if the car was running lean or rich and it wasnt doing either, but i think it must of been pinging a bit because there was a slight metallic look on the plugs ( well i think my mate and i thought there was ). That chip does make the car running at 40 degree advance so yea, just to be safe i have taken the chip out again and will wait until i can get the car on the dyno with all the sensors hooked up, so i know the chip is totally safe. I'm pretty sure it is safe, and that the spark plug was normal ( we're not professionals when it comes to reading spark plugs ) so until i find out for sure, im going to stick with the normal ecu chip. Better safe then sorry though aye... Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted November 30, 2007 Well i found a place who could burn my chip for me, and i got it done, cost me $20 tho. I put it in and i could notice the difference, the car was running really well. I took a plug out to check to see if the car was running lean or rich and it wasnt doing either, but i think it must of been pinging a bit because there was a slight metallic look on the plugs ( well i think my mate and i thought there was ). That chip does make the car running at 40 degree advance so yea, just to be safe i have taken the chip out again and will wait until i can get the car on the dyno with all the sensors hooked up, so i know the chip is totally safe. I'm pretty sure it is safe, and that the spark plug was normal ( we're not professionals when it comes to reading spark plugs ) so until i find out for sure, im going to stick with the normal ecu chip. Better safe then sorry though aye... Get it on a dyno - there are guys who can tune that montronic chip on the fly on a dyno. 40deg of timing advance sounds a little scary to me. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted November 30, 2007 Get it on a dyno - there are guys who can tune that montronic chip on the fly on a dyno. 40deg of timing advance sounds a little scary to me. What is the process for this tuning ? Sounds interesting Do they use a Rom emulator on the dyno and compare wide band exhaust results between runs and then just burn the chip at the tune that works ? Quote Share this post Link to post Share on other sites
