charles28 142 Report post Posted November 29, 2007 Since installing an aftermarket headunit into my E36 the radio reception has been pretty bad. From what I can tell the back window heater is the aerial.. its almost like it needs some kind of signal booster.. When i disconnected the factory headunit there was a thin wire connecting to the back of the headunit that was labelled 'AMP'. I am thinking this is something to do with powering the factory signal booster, however if this is the case, where can i connect it to? could I wire it upto the 12v from the headunit perhaps? surely someone else has had this problem. Thanks Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted November 29, 2007 No problems using aftermarket headunits. You are right - the aerial is a surface one in the rear windshield. The only aerial wire I plugged in on any aftermarket headunit was the aerial plug from the old headunit, and everything works perfectly. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted November 29, 2007 there is a skiny white wire that needs to conected to your blue electric aerial output wire to send 12volts to the booster unit in the left rear c pillar Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted November 29, 2007 (edited) there is a skiny white wire that needs to conected to your blue electric aerial output wire to send 12volts to the booster unit in the left rear c pillari was going to type in prety much what he said. Edited November 29, 2007 by btccm3 Quote Share this post Link to post Share on other sites
