pureboiracer 0 Report post Posted January 18, 2008 i was reading a post just before and someone said that there is a difference between a pfl 320i airflow meter and a fl 325i airflow meter. my pfl one fits and everything but i hav a problem of the engine failing under any kind of load. they also said there was a difference in the fuel pumps?? can anyone confirm this and if they are different does anyone have the fuel pump and airflow meter from a fl 325i with motronic 1.3? cheers oli Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted January 19, 2008 yo need 325i afm to match the ecu engine you are using face lift type Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 19, 2008 I have one (AFM) Ph me (09) 2722546 or 021921377 The fuel pump wont matter...so long as its working Should deliver 2.5 bar with vacuum 3.0 bar without vacuum Measured at the fuel rail (inlet side) not return hose Cheers Glenn Quote Share this post Link to post Share on other sites
