robert.fowler 0 Report post Posted February 6, 2008 does anyone know where i can get a manual pedalbox and manual console face with the gearlever boot for a E36 Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted February 7, 2008 does anyone know where i can get a manual pedalbox and manual console face with the gearlever boot for a E36 No need to get a full pedalbox. All you need is the clutch pedal/cylinder,hose etc. The pedal boxes are the same across the board. 318-m3 manual to auto. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted February 7, 2008 Not mant wreckers will split them up either now. They only selling whole kits because of demand Quote Share this post Link to post Share on other sites
westy 614 Report post Posted February 7, 2008 Reasonably cheap new from BMW. You need the brake pedal as well as the clutch pedal. Might as well replace all the bushings at the same time. Have a look at the on line ETK (stickied in gen discusion) for a blow up diagram. You can do without the overcenter helper spring if you dont mind a heavier clutch. Both pedals hang of the same bracket auto or manual. Quote Share this post Link to post Share on other sites
