OLLIE
Fuel Tank where to get one cleaned?
can anyone recommend where to get a fuel tank washed out and tested for leaks also welded if necessary?
I had a leak in mine (on the 2002) repaired at the radiator place in Newton called ... google ... Auto Radiators, Nixon St. I was happy enough (it worked, wasn't stupid expensive).
You could also try Vercoe radiators in Newmarket...ask for Maurice. They have done tanks for me before. There phone number is 5248028
