mops 4 Report post Posted March 3, 2008 As title and description says, I'm after a stock differential in preferably good condition , with 3.25 or 3.46 ratio. I want the NON-LSD unit, i.e. stock open diff. Ideally auckland pickup... Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted March 4, 2008 i have some , for what model , e30 or e36 , e28 etc . 021433600 Quote Share this post Link to post Share on other sites
mops 4 Report post Posted March 14, 2008 i have some , for what model , e30 or e36 , e28 etc . 021433600 hey brent. I did some research and as far as I can find, all medium case diffs are the same, and just have different backplate between various models.... can have a look and confirm please? how much would you want for one anyways ? I kinda need it asap. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 14, 2008 hey brent. I did some research and as far as I can find, all medium case diffs are the same, and just have different backplate between various models.... can have a look and confirm please? how much would you want for one anyways ? I kinda need it asap. No they are not E30 & E36 are very different in their front mounting positions on the body of the diff as well as having different rear plates. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted March 14, 2008 yes e30 and e36 do have different front mount castings , old e28 use similer case to e30 . but you can take the gears from one newer casing and fit to old type etc . Quote Share this post Link to post Share on other sites
mops 4 Report post Posted March 16, 2008 yes e30 and e36 do have different front mount castings , old e28 use similer case to e30 . but you can take the gears from one newer casing and fit to old type etc . so i'm a bit lost here. you you are saying e36 might diff will not fit into e30, but e28 medium case will ? how much are you after for that e28 3.46 one ? I think 325i's auto's had factory 3.46 diffs. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 16, 2008 yes he is, the E36 diff will not fit an E30, but the E28 diff will, so long as you change the back plate and the output shafts. This is an easy thing to do, the back plate is just unbolt and bolt up, and the output shafts are just lever out and push in. The other options are the E23 and E24 diffs, same story as the E28. Quote Share this post Link to post Share on other sites
