xtr041947 0 Report post Posted March 12, 2008 Hi whats the deal with BMW's lifetime oil in the transmissions, do you need to service them? Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted March 12, 2008 Hi whats the deal with BMW's lifetime oil in the transmissions, do you need to service them? Nothing will last forever, so yes. People do change the fluid. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 12, 2008 We do a transmission service on "lifetime" transmissions at 100,000km The right oil "MUST" be used and change the filter and pan gasket There is a proceedure for topping up and checking the oil after doing this Quote Share this post Link to post Share on other sites
NVADER30 0 Report post Posted March 14, 2008 What sort of cost would you be looking at for an e36 auto trans...anyone know? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 14, 2008 What sort of cost would you be looking at for an e36 auto trans...anyone know? If it has " lifetime" trans approx $400 incl to do the service. Oil, filter, pan gasket, scan, reset adaptions, road test and recheck. Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 14, 2008 If it has " lifetime" trans approx $400 incl to do the service. Oil, filter, pan gasket, scan, reset adaptions, road test and recheck. IF you pay that much you're getting ripped off, I paid less than $180 for mine - can't remember how much exactly, I'll try dig out the last service receipt for the 320 ... Quote Share this post Link to post Share on other sites
isis 16 Report post Posted March 14, 2008 e36's dont have life time fluid stickers on their box. e46's/e39 etc etc do... Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted March 14, 2008 E36 facelift do use lifetime oil (at least mine is) Was quote $850 by another BMW Sepcialist to do the same procedure. Apparantly, those "lifetime" fluid (Esso LT71141 or equiv.) are real expensive. To the point that BMW's maintainance documents (TIS) actually say those fluid are meant to be saved and reuse if transmission service is needed. Go figure. $180 was more like the standard stuff. That's what a Honda Civic would cost for a tranx fluid change. Quote Share this post Link to post Share on other sites
Muzzie 0 Report post Posted March 14, 2008 e36's dont have life time fluid stickers on their box. e46's/e39 etc etc do... My gfs E36 318iS has a big sticker on the trans sump saying it has lifetime fluid........... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 14, 2008 (edited) IF you pay that much you're getting ripped off, I paid less than $180 for mine - can't remember how much exactly, I'll try dig out the last service receipt for the 320 ... Ripped off ???? Bullshit ....go do your maths The fluid is $28.46 a litre +GST, filter & pan gasket $100 (OE is is more expensive) + 1hr labour +gst If thats all it cost you, they used the wrong oil and didnt do it properly, thats if your trans is "longlife" If its not longlife $180 is still cheap, and they probably didnt use full synthetic, or remove the pan & filter. Did they just drain and refill with new oil ??? if so, thats not doing the job properly. You actually got what you paid for " a cheap job " Edited March 14, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 14, 2008 E36 facelift do use lifetime oil (at least mine is) Was quote $850 by another BMW Sepcialist to do the same procedure. Apparantly, those "lifetime" fluid (Esso LT71141 or equiv.) are real expensive. To the point that BMW's maintainance documents (TIS) actually say those fluid are meant to be saved and reuse if transmission service is needed. Go figure. $180 was more like the standard stuff. That's what a Honda Civic would cost for a tranx fluid change. I saw that in TIS.....I would never reuse old oil, how friggen silly is that. $850 was a "little" over the top. And half the time most dont Scan and clear adaptions because they dont have the equipment. To do it properly, its not a "5min" job and you need to let it drain with the filter off for at least an hour to allow the torque convertor to drain. Done properly it will take approx 5 litres of fluid. Quote Share this post Link to post Share on other sites
Court M3 0 Report post Posted March 15, 2008 change mine in the X3. I'll believe their lifetime fill when they give me a lifetime gaurantee Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted March 15, 2008 I'll believe their lifetime fill when they give me a lifetime gaurantee +1 Well said~ Quote Share this post Link to post Share on other sites
