Justlikemusic 0 Report post Posted March 17, 2008 Will these rims fit my E30? I am unsure of the offset! They are for sale, $200 http://i18.ebayimg.com/06/i/000/e0/7a/5950_1.JPG 4 x CSA 16" Alloy Rims / Mags, made in Australia by Mullins Wheels 6.5J x 16H2 rim offset With Veritus HRII 205 / 45 / 16 low profile tyres Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 17, 2008 You need to know the stud pattern and offset. You want 4 x 100 for the studs, and offset between 15 and 25, maybe up to 30 for a 6.5 inch rim.. Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted March 17, 2008 if their the same as my gf's old mags, they didnt fit, believe me I tired They just ground on my brake caliper at the front, was quite horrible. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted March 17, 2008 Sometimes for clearance, a lot of it is down to spoke design. e.g. ET20 minilights 15x6.5 didn't clear my E30's calipers, whereas the oem 14x6 ET35 did. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted April 11, 2008 You need to know the stud pattern and offset. You want 4 x 100 for the studs, and offset between 15 and 25, maybe up to 30 for a 6.5 inch rim..6" rim width: 35mm offset6½" rim width: 30mm offset 7" rim width: 25mm offset 8" rim width: 15mm offset Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted April 11, 2008 6" rim width: 35mm offset 6½" rim width: 30mm offset 7" rim width: 25mm offset 8" rim width: 20mm offset - will help to clear guards 9" rim width 15 -10mm depending on front struts ^ thats a general rule, as the rims get wider you have to get closer to the optimum offset. and as others have said some spoke designs wont clear the calipers. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 11, 2008 You can find another 15mm clearance for the inside if you go back to solid brake disks and calipers, instead of the vented, stops the inside of the spokes hitting the calipers, makes little difference to the average driver. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted April 11, 2008 Haha, Well I just copied from a website so shows what i know about offset. Quote Share this post Link to post Share on other sites
Driftit 2245 Report post Posted April 22, 2008 I fit 15X8 +0 on my E30 no problem. Just roll the rear guards slightly but nothing major. But I think the best offset would be +10 or less. Quote Share this post Link to post Share on other sites
