tibbs.james 1 Report post Posted March 26, 2008 The other day while fitting a 325 Swaybar & some urethane i noticed the rubber boots and covers on all my front ball joints were split. So i have 4 replacment ball joints i can press in once i get the old ones pressed out. only i can't seem to get the inner ball joints out of the crossmember. ive tried giving the drivers side a bash but its pretty well stuck & that still dosn't help me with the passenger side one as thats impossible to get to withot removing a whole bunch of stuff. The outer ball joints needed a really good bash too but they are easy to get at. Help really appreciated as i need to get these off before friday night. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 26, 2008 I use a spray you can get from repco called Penetrate pretty sure its a CRC product... seriously .. spray it on, leave it 5 minutes and out she comes with a bit of a hammer on the support areas ... If you dont already know .. never hit the actual ball joint, it just destroys it. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted March 26, 2008 support area as in from underneath the car ? If so i will give it a shot. Ball joints ( both on each side ) are being replaced with brand new out of the box units. So i only need to get everything off so they can be pressed out. I would never hit a ball joint with a hammer if i planned to use it ever again. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted March 26, 2008 "325 Swaybar & some urethane" Nice nice Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted March 26, 2008 support area as in from underneath the car ? yip, whack the subframe where the ball joint runs through. make sure when you press the new ball joints in that they are aligned correctly. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted March 26, 2008 (edited) Speaking of swaybars hows the other one coming along Riley ? and we have a winner Note the CRC PENETR8 Thanks guys Now off to my engineering who has the press ( I'm going to let him press in the ball joints as i don't trust myslef ) Edited March 26, 2008 by Jimmy Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 26, 2008 Yeah its badass sh*t aye ... did the whole e30 with it and its 21year old parts .. glad it worked for you too Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted March 26, 2008 Has anyone used both PB Blaster and Penetr8, just wondering how they compare (I've only had experience with PB Blaster) Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted March 26, 2008 On the Nissan Z31 forum all the USA guys go on about using PB Blaster saying its great so i guess they both do the job. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted March 26, 2008 Its going to be a little while dude, maby a month if thats all good Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 28, 2008 How much were your ball joints? BTW the bentley says whack the inner joint out with a soft faced hammer (presumably so you don't bend the subframe as it is softer than the cast strut mount point you hit for the outer joint). As you know there is no room to swing a hammer in there, so I got a long peice of timber and whacked it from the engine bay - came out easy enough. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted March 28, 2008 (edited) Not sure if i should've or not but i just opted for the cheap option when i was doing my urethane, brand new C-Arm for $130 from GAC. Seems alright, not OEM but i dont drive the car a lot Edited March 28, 2008 by Chris C Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted March 29, 2008 I paid $150 for ball joints on both sides from a friend who owns a Euro parts business. I asked him to order me 2 x complete arms as he had arms for everything else But instead he just pulled some ball joints off the shelf so that was good enough for me. Quote Share this post Link to post Share on other sites
