cammy83 0 Report post Posted March 30, 2008 I would like to know whether it's common for my bmw's temperature to go to half when I have been driving the car for a while then back to near the blue part (showing cold) and then moving towards half way a few times? Is this normal or does that mean that there is a problem with the temperature? I am not sure whether I should get the car checked out for this issue. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 30, 2008 (edited) I would like to know whether it's common for my bmw's temperature to go to half when I have been driving the car for a while then back to near the blue part (showing cold) and then moving towards half way a few times? Is this normal or does that mean that there is a problem with the temperature? I am not sure whether I should get the car checked out for this issue. It should run half way all the time. You could have a thermostat problem. Get it checked. No1 reason for BMW engine failure is always temperature related. Jammed open not so bad, but it may also jam closed= overheating. Best advise is get it checked out as soon as you can Cheers Glenn BTW....these sort of questions should be in "maintenance" Edited March 30, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted March 30, 2008 i agree , just about every engine i sell is to replaced a over heated (cooked engine) ,, faulty thermostats , broken water pipe ,hoses split , water pump leaking , and they say to them selves , just gotta get home instead of calling a tow truck etc . $100 for a tow $2000 for an engine????? Quote Share this post Link to post Share on other sites
