325_driver
Automatic transmission
hey guys
taking an auto transmission off
it doesn't reverse and apparently theres some valves that will just need cleaning and bearing that needs replacing
by any chance does any one have pictures of what i am going to be looking at ?
ive never really had any thing to do with automatic trans's
hey guys
Off which model and chassis of bmw
Looking at what? removing the transmission? Replacing the bearing/valve or something else?
edit: what model it is, would help.
Edited by QuickSilver
Sorry guys.
But you are totally out of your depth here..325_driver
You are taking on far more than you may think. Even proffessional repair shops use professional transmission shops to do transmissions these days.
Hi
losing reverse was the first sign when two of my auto transmission were just about gone, is the car slipping at all when changing gears? or have power loss in first gear as that was the next to go on mine.
just putting in my two cents, i found it cheaper to replace with a second hand gearbox only cost me around $350 from a wreakers but have seen them cheaper
unless you dont mind paying for professional to check it out
Hi
no slipping what so ever
no power loss in any of the foward gears
it has to be some thing stupid
because it goes forward in park, neutral, reverse, and every other gear
As said earlier, an auto trans is a specialist field - get it checked by a proffesional for an appraisel
