topcat 11 Report post Posted April 14, 2008 Hi all this will be the last week that my e28 will on all 4 wheels. any one keen on owning this machine/or part of,please speak up. Other wise you'll have to take my word for it. engine $5000 box,kit + clutch $2100 marty 021 438 735 Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted April 15, 2008 That sucks - someone buy this piece of badassness before I get all impulsive. Quote Share this post Link to post Share on other sites
M3 Cab 0 Report post Posted April 15, 2008 That sucks - someone buy this piece of badassness before I get all impulsive. and buy it with what magic beans Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted April 15, 2008 and buy it with what magic beans rofl Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted April 15, 2008 rofl i'm rick james bitch Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted April 25, 2008 (edited) hey whats included? is it ready to be put in a e30 or does it still recquire wiring harness etc....? would you posably do a deal for this? swap for my m20 and cash? For this purpose built engine alot of parts were bought new last year and has bout 4000k's on it.max.will include; early e34 3.5L block,prepd/honed and cracked checked.pistons ,not new but were check over for wear etc, low compression.new rings.bearings new.crank,poslished and balanced.new seal kit.new MLS gasket.new cam chain.new adjusted cam sprocket.new oil pump chain.oil pump used but stripped and checked over by prof.head,e32 ,skimmed,checked over.new valves.springs.stem seals.re-ground cam for more duration.new head bolts.port matched inlet manifold.fittings for hoses drilled and taped under throttle body for ecu/boost control.new 450cc injectors.fuel rail cleaned and checked for cracks.new water pump.new belts.new spark plugs.new distributer and rotor.new v band t-61 turbo.new feed/return oil line.manifold is self made but machined and finished by local engineering firm for trueness.new gaskets. new 38mm tail wastegate/15lb spring engine has done 1000k's NA breaking in carefully and 2-2500k's with turbo.all this goodness $5000 probably could add afew other bits,but this list is worth big $$. forgot,e28 oil cooler and low temp thermostat do the maths and price up some for this stuff,you'll fall off your chair wireing harness can be purchased for $180.. yes with some fabing of new engine mounts,it will slide it your e30.not that interested in your m20.try TM you got a m30 box to go behind it? theres a 260 box with bits on TM at the mo.good price too. Edited April 25, 2008 by topcat Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted April 28, 2008 For this purpose built engine alot of parts were bought new last year and has bout 4000k's on it.max.will include; early e34 3.5L block,prepd/honed and cracked checked.pistons ,not new but were check over for wear etc, low compression.new rings.bearings new.crank,poslished and balanced.new seal kit.new MLS gasket.new cam chain.new adjusted cam sprocket.new oil pump chain.oil pump used but stripped and checked over by prof.head,e32 ,skimmed,checked over.new valves.springs.stem seals.re-ground cam for more duration.new head bolts.port matched inlet manifold.fittings for hoses drilled and taped under throttle body for ecu/boost control.new 450cc injectors.fuel rail cleaned and checked for cracks.new water pump.new belts.new spark plugs.new distributer and rotor.new v band t-61 turbo.new feed/return oil line.manifold is self made but machined and finished by local engineering firm for trueness.new gaskets. new 38mm tail wastegate/15lb spring engine has done 1000k's NA breaking in carefully and 2-2500k's with turbo.all this goodness $5000 probably could add afew other bits,but this list is worth big $$. forgot,e28 oil cooler and low temp thermostat do the maths and price up some for this stuff,you'll fall off your chair wireing harness can be purchased for $180.. yes with some fabing of new engine mounts,it will slide it your e30.not that interested in your m20.try TM you got a m30 box to go behind it? theres a 260 box with bits on TM at the mo.good price too. soooo..... any takers???? Quote Share this post Link to post Share on other sites
chompa 0 Report post Posted April 30, 2008 man i would soo be keen if i had the dosh and wasnt a poor student now......how much power? Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted April 30, 2008 man i would soo be keen if i had the dosh and wasnt a poor student now......how much power? 380rwhp, s**t load of torque. Quote Share this post Link to post Share on other sites
