325_driver 422 Report post Posted April 16, 2008 hey guys 4 door e30 question here since it looks pretty simple but is prooving to be harder than expected. inserting the triangular piece of window, (rear right on the e30 between window and pillar) how do i insert it ? e.g. do i need to take the whole door apart ? thanks Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 16, 2008 From memory, I think the window glass needs to come out first, the divider can then be slid forward to allow access of the Qtr window Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 16, 2008 hey guys 4 door e30 question here since it looks pretty simple but is prooving to be harder than expected. inserting the triangular piece of window, (rear right on the e30 between window and pillar) how do i insert it ? e.g. do i need to take the whole door apart ? thanks You need to take out the window regulator and main glass first and then the window guide that holds the 1/4 glass in, which means basically you strip the door apart unfortunately. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted April 16, 2008 saves me alot of hassle having that info cheers, and i take it the regulator is the black divider between the windable window and the triangular piece of glass ? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 17, 2008 saves me alot of hassle having that info cheers, and i take it the regulator is the black divider between the windable window and the triangular piece of glass ? No, The regulator is the mechanism that supports/ winds the window up & down - remove this to be able to remove the main glass Quote Share this post Link to post Share on other sites
