325_driver 422 Report post Posted April 19, 2008 another part im looking for in my e30 as the linkage is broken just as a question, would it be an easy option to just install a electric sunroof? as its just a manual winder since i could salvage one from my other e30, if thats going to be too much hassle, who do i get the sunroof mechanism from? thanks Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted April 19, 2008 i have electric sinroof motor. 021433600 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 19, 2008 You can convert from manual to electric - I have done one before. A bit of effort & 2-3 hrs work - you need to remove & swap the whole rack assy - meaning removing lid, overhead console & trim/frame work of sunroof, swapping rack assy, mounting motor assy, run wire down pillar & connect to power source (already there). Reassemble in reverse. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted April 19, 2008 You can convert from manual to electric - I have done one before. A bit of effort & 2-3 hrs work - you need to remove & swap the whole rack assy - meaning removing lid, overhead console & trim/frame work of sunroof, swapping rack assy, mounting motor assy, run wire down pillar & connect to power source (already there). Reassemble in reverse. am i going to have to remove sunroof ? oh btw, since i have major sunroof leaks how do i get the sunroof out to do its seals cheers Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted April 19, 2008 (edited) Changing the sunroof from manual to electric is easy az. You dont need to change jack all except the the manual winder unit with the electric one. and the roof interior trim part, ( one the sunvisors screw to) wiring it in is simple aswel. You only need to run a power (only on when key is on)and earth up one of the pillars to the electric unit. ive also got the parts needed and can write a description of how to install if needed. Could be done in an hour easy I rekon. To remove the roof liner in one piece is probably the hardest part if you need to take the sunroof out completely. Once you have that off taking the sunroof out is fairly strait forward. Edited April 19, 2008 by 323e30 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted April 19, 2008 Changing the sunroof from manual to electric is easy az. You dont need to change jack all except the the manual winder unit with the electric one. and the roof interior trim part, ( one the sunvisors screw to) wiring it in is simple aswel. You only need to run a power (only on when key is on)and earth up one of the pillars to the electric unit. ive also got the parts needed and can write a description of how to install if needed. Could be done in an hour easy I rekon. To remove the roof liner in one piece is probably the hardest part if you need to take the sunroof out completely. Once you have that off taking the sunroof out is fairly strait forward. yeah i have one in my old e30 that should be sweet what about running a power up from the stereo acc wire ? same diff aye ? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted April 20, 2008 yeah i have one in my old e30 that should be sweet what about running a power up from the stereo acc wire ? same diff aye ? Pritty much really, it will work sweet, if it blows fuses find a diff source tho, dont go putting a bigger fuse in haha. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 20, 2008 Changing the sunroof from manual to electric is easy az. You dont need to change jack all except the the manual winder unit with the electric one. and the roof interior trim part, ( one the sunvisors screw to) wiring it in is simple aswel. You only need to run a power (only on when key is on)and earth up one of the pillars to the electric unit. ive also got the parts needed and can write a description of how to install if needed. Could be done in an hour easy I rekon. To remove the roof liner in one piece is probably the hardest part if you need to take the sunroof out completely. Once you have that off taking the sunroof out is fairly strait forward. Stand to be corrected, but news to me... - last time I looked the mechanisms were different - otherwise I would simply have swapped winder mechanisms & not the whole thing. Also, you don't need to run an earth wire - the earth connects to the car at the top beside the motor. The power supply is as I said - already there, behind glovebox (plug & play). DONT pick up from the stereo. Also, to change as I described, as I said - you need to remove the lid, depending where your leak is - it could be due to rust in the lid/frame or blocked drain holes in each corner of frame - the seal around the edge of the lid is not intended to be water proof - water getting in should drain through the designated drains in the frame Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted April 20, 2008 ok, will get hood linings off and start piecing it together as with the leaks probably best bet would be to get it open and have a look i suppose and no doubt ther will probably be rust in front of me thanks hotwire Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted April 21, 2008 (edited) Theres probably a difference between face lift and pre face lift tho sunroof winder rails. Ive always owned pre facelifts so its a strait swap. You should put the switch for the roof winder down by the window switches while your at it, Saves the hassle of reaching up. And use the non sun roof type trim so theres no hole where the winder or switch were. Edited April 21, 2008 by 323e30 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted April 21, 2008 Theres probably a difference between face lift and pre face lift tho sunroof winder rails. Ive always owned pre facelifts so its a strait swap. You should put the switch for the roof winder down by the window switches while your at it, Saves the hassle of reaching up. And use the non sun roof type trim so theres no hole where the winder or switch were. have you got that non sunroof trim? not sure how much damage im going to do removing mine Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted April 27, 2008 have you got that non sunroof trim? not sure how much damage im going to do removing mine i think i do, ill check tommorow and get back to you. its easy to take off. but two of the screws are hiding in the sunroof gutter , you should see where i mean when you get started Quote Share this post Link to post Share on other sites
