keen 6 Report post Posted April 21, 2008 can Anyone in here tell me how to tension up the cam belt to the correct tension? or some easy way of doing it/ Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 21, 2008 (edited) can Anyone in here tell me how to tension up the cam belt to the correct tension? or some easy way of doing it/ BMW use a special tool to tension the belt, worth $$$ ..... I use experience You shouldnt over tighten it. The rule of thumb is....you should be able to turn the belt 90 degrees on the driven side ( intake side ) Do you have a workshop manual or the correct instructions for doing this ?? If you dont get the timing right.....YOU WILL DAMAGE SOMETHING Edited April 21, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
keen 6 Report post Posted April 22, 2008 BMW use a special tool to tension the belt, worth $$$ ..... I use experience You shouldn't over tighten it. The rule of thumb is....you should be able to turn the belt 90 degrees on the driven side ( intake side ) Do you have a workshop manual or the correct instructions for doing this ?? If you don't get the timing right.....YOU WILL DAMAGE SOMETHING thankyou yes I have the BMW instructions they were printed out for me by a friend but did not have the special tool, and was wondering how other mechanic's do it without the special tool. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted April 23, 2008 You can use an Allen key and a spring scale (the type you would use to weigh a fish) With the Allen key in the tensioner pulley, place the spring scale 85mm along the key and pull until you reach 2kg on the scale. Keep the scale at 90 degrees to the key. Quote Share this post Link to post Share on other sites
