325_driver 422 Report post Posted April 22, 2008 hey guys in the process of doing an engine transplant im converting what was a e30 320, m20b25 to a 325, m20b25 run into a little problem obviously im going to have to swap ecu's i have a process already in mind but i was wondering what others have done, if some ones converted b20, to b25 in e30's? save me the hassle, thinking about uncliping b25 ecu, and feeding the plug with the pins, back through the firewall some how and then feed it into the new e30? save me cutting wires and rewiring countless things ? Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted April 22, 2008 A wise man (Will) once told me, if you have it all together, wiring ecu etc, its as simple as using all the wiring from the b25, and just pushing the wiring through the firewall and connecting it to the ECU. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted April 22, 2008 A wise man (Will) once told me, if you have it all together, wiring ecu etc, its as simple as using all the wiring from the b25, and just pushing the wiring through the firewall and connecting it to the ECU. interesting, we must think alike Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted April 23, 2008 interesting, we must think alike I would have to agree on that too Quote Share this post Link to post Share on other sites
