chrisvlok 0 Report post Posted April 28, 2008 hi all, i am wanting to buy this 318i off tm as my race car, thing is, im not to sure whether it is the fuel pump for sure? he said he was driving around, stopped at a set of lights, and then when he pulled off he slowly lost power and managed to cost off the road. does that sound like the fuel pump? i was thinking maybe the coil's stuffed or something electrical? http://www.trademe.co.nz/Browse/Listing.aspx?id=152571048 even if this is major, im thinking its still a pretty good buy to do a engine swap with my 325i. whats your ideas guys? thanks Quote Share this post Link to post Share on other sites
Eagle 1702 Report post Posted April 29, 2008 Could be something simple as DME or fuel pump relay if you cant hear the pump running Quote Share this post Link to post Share on other sites
eurobandit 0 Report post Posted April 29, 2008 hi all, i am wanting to buy this 318i off tm as my race car, thing is, im not to sure whether it is the fuel pump for sure? he said he was driving around, stopped at a set of lights, and then when he pulled off he slowly lost power and managed to cost off the road. does that sound like the fuel pump? i was thinking maybe the coil's stuffed or something electrical? http://www.trademe.co.nz/Browse/Listing.aspx?id=152571048 even if this is major, im thinking its still a pretty good buy to do a engine swap with my 325i. whats your ideas guys? thanks hi ive had a simular problem in my old e30 320 manual,every now and again would stop for no reason,we put it up on the hoist to discover the earth wire for the fuel pump was stuffed,it would make connect most of the time then sometime wouldnt.not saying this is the problem but its a maybe Quote Share this post Link to post Share on other sites
chrisvlok 0 Report post Posted April 29, 2008 Could be something simple as DME or fuel pump relay if you cant hear the pump running hi, thanks for the help. what is a dme? thanks Quote Share this post Link to post Share on other sites
chrisvlok 0 Report post Posted April 29, 2008 hi ive had a simular problem in my old e30 320 manual,every now and again would stop for no reason,we put it up on the hoist to discover the earth wire for the fuel pump was stuffed,it would make connect most of the time then sometime wouldnt.not saying this is the problem but its a maybe thanks. i am going to have a look at it tonight, what should i look out for? Quote Share this post Link to post Share on other sites
Eagle 1702 Report post Posted April 29, 2008 DME(Digital Motor Electronics) is the main engine computer relay Quote Share this post Link to post Share on other sites
Eagle 1702 Report post Posted April 29, 2008 Come to think about it that is L-Jetronic im sure & didnt have DME, someone might be able to confirm?. Quote Share this post Link to post Share on other sites
eurobandit 0 Report post Posted April 29, 2008 thanks. i am going to have a look at it tonight, what should i look out for? sorry for delay,how i discovered this problem was,a mate turned over the car while i moved the wire. Quote Share this post Link to post Share on other sites
chrisvlok 0 Report post Posted May 2, 2008 hi guys, thanks for the help, i ended up buying the car, put a new fuel filter and pump in and she's all go. i painted it yesterday with m stripes and took at least 20 kg out. starting to take shape. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 2, 2008 DME(Digital Motor Electronics) is the main engine computer relay DME = the ECU The relay = the DME relay 2 different things Quote Share this post Link to post Share on other sites
