petone 0 Report post Posted July 12, 2004 Hi guys, just curious as to what sort of gas you put in your cars? Can they take 91 or should it be like 96 minimum? I always use 96 and I was thinking about playing round with ignition timing but if it should have 96 anyway then i wouldn't bother. How much differnce does advancing the timing make? Worth mucking round with or better left alone? Andrew, I noticed you had done this to your 320i, what did you think of it? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 12, 2004 always use 96, the stock engine timing is designed for that...gull 97 IMO is the best...same price as 96 too.....on the 320 it made a huge diff...didnt make much of a diff on the 318 though, and you always need to run 98.....to be honest i wouldnt bother trying to screw power outta an m10...just enjoy going round corners fast Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 12, 2004 well obviously you want a fuel thats harder to burn when you advance the timing - this will prevent pre-ignition. The 320 gained a hheeapp load more power with 20deg timing advance running 98. The m10 318 got timing advance done on 91 of 10 deg or so with a bit more driveability - it is my mums car so we didn't wanna go 98 it and try run 25 deg advance or something. It may be worth a try on your car. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted July 13, 2004 I'll have to think about it then, I don't know exactly what I'm doing, I only know the basic idea. I'd have to get someone from BS down here to help, (Looking at carl or glenn here). So you think I could still advance it a bit using 96? Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted July 13, 2004 andrew. turns out my engine is pre-facelift so can i advance my timming now???? would i need to run 98? cos i run 96 at the moment Quote Share this post Link to post Share on other sites
petone 0 Report post Posted July 13, 2004 turns out my engine is pre-faceliftSo is your car facelift? You can tell if your timing is adjustable if you have a small box with two plugs going into on the side of your engine bay, should have telefunken written on it. Also your dizzy should be driven off the block as opposed to the head. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted July 13, 2004 yea my car is f**ked up its facelift with a pre-facelift engine well thats wat gus told me and i hav a fcelift airbox or somthihng i have a look for that next time im under the hood Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted July 13, 2004 looks like the owner fried the original engine then, and slapped in another , shifty Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted July 13, 2004 looks like the owner fried the original engine then, and slapped in another , shifty yea thats wat im thinking. but of cors i want do everyone wants to do and put in a 325i engine anda 5-speed box!! but thats not for a couple miles down the track Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 13, 2004 although it is an early facelift...coulda been when they were using facelift bodies but pre facelift engines...andys suggestion from tonites musings Quote Share this post Link to post Share on other sites
nath 183 Report post Posted July 14, 2004 Yea thats crazy bout ur engine dude- but i gotta admit i was impressed by ur car yestaday- itll b a good looka wen its running with sum decent(at least bottlecaps) rims...... DEGREASE THE ENGINE! Quote Share this post Link to post Share on other sites
nath 183 Report post Posted July 14, 2004 Well i gotta say, my car HATESSSS te 91 fuel, but likes 96 an loves anythin higher!! Definitely notice the diff Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted July 14, 2004 tell be about it. i have the best of both worlds. a pre-face lift body with a facelift motor(motronic) Quote Share this post Link to post Share on other sites
petone 0 Report post Posted July 14, 2004 i have the best of both worlds. a pre-face lift body with a facelift motor(motronic) So do you like the look of the pre FL better or someother reason like cost? Just a random question - Was 86' the first year they made a 325i then? Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted July 14, 2004 yea i will get around to degreasing the engine sometime after i get it serviced.. no point in having a nice clean engine when it isnt running properly yea and bottle caps are at the top of the list after servicing i only need two more Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted July 14, 2004 i have the best of both worlds. a pre-face lift body with a facelift motor(motronic) So do you like the look of the pre FL better or someother reason like cost? Just a random question - Was 86' the first year they made a 325i then? correct me if im wrong, mine was one of the first M20B25 motor in an E30 shell.also mine came with full electrics and cruze control i love the crome bumbers and the window trims FL one's didnt come with crome bumbers. even though they are abit heavier the the plastic ones. Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted July 15, 2004 Ack chrome! It burns us! Quote Share this post Link to post Share on other sites
Guest WAGON Report post Posted July 15, 2004 i seem to like the fl bumpers way better than the chrome ones and black window trim is so sexy :mosh: Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted July 15, 2004 i have the best of both worlds. a pre-face lift body with a facelift motor(motronic) So do you like the look of the pre FL better or someother reason like cost? Just a random question - Was 86' the first year they made a 325i then? correct me if im wrong, mine was one of the first M20B25 motor in an E30 shell.also mine came with full electrics and cruze control i love the crome bumbers and the window trims FL one's didnt come with crome bumbers. even though they are abit heavier the the plastic ones. Your sort of wrong - All 325 (yep 325, 325e, 325i) are motronic 1.1 or higher. The 325i came out in prefacelift in 1986 I think and had the motronic 1.1 motor - (what my car has also Tim). Some later prefacelift cars (such as ollies 320i) had Motronic 1 systems. Essentially fancy L-Jetronic. Quote Share this post Link to post Share on other sites
