wild_weston 0 Report post Posted May 2, 2008 Hi All, just wondering if anyone knows the replacement size for wipers on the E46, and whether the drivers and passengers are the same size. My wipers are a bit juddery right now so want to replace them. Had a look on the back of the packets in REPCO and couldn't find any for the E46. If you know the sizing please post a reply. Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 2, 2008 (edited) Hi All, just wondering if anyone knows the replacement size for wipers on the E46, and whether the drivers and passengers are the same size. My wipers are a bit juddery right now so want to replace them. Had a look on the back of the packets in REPCO and couldn't find any for the E46. If you know the sizing please post a reply. Thanks You probably only need rubbers. We use quality BOSCH refills and cut them to size . The size we use is 600mm Be carefull buy quality... alot are plastic....try and get the BOSCH ones from Autostop Part # BMN610-20 Edited May 2, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 3, 2008 Hi All, just wondering if anyone knows the replacement size for wipers on the E46, and whether the drivers and passengers are the same size. My wipers are a bit juddery right now so want to replace them. Had a look on the back of the packets in REPCO and couldn't find any for the E46. If you know the sizing please post a reply. Thanks I had to replace mine last weekend. The blades themselves had lost all tension and were really noisy - not to mention the knackered refills. $130 for new genuine BMW blades and refills (RH $80+GST, LH $32+GST) from Team McMillan in Auckland. Kind of pricey, but they are so quiet and I can see in the rain again. If you just need refills, you should be able to grab a sample at Repco or Autostop to check the width and length against the car (they have always allowed me to do this). And as Glenn says - try to use good quality ones like Bosch. Nothing worse that not being able to see in the wet... Sounds like you and I have got sister cars..... Quote Share this post Link to post Share on other sites
wild_weston 0 Report post Posted May 3, 2008 Ta for the replies botanay and elmarco. I'll try repco next weekend. Cheers Quote Share this post Link to post Share on other sites
wild_weston 0 Report post Posted May 4, 2008 (edited) You probably only need rubbers. We use quality BOSCH refills and cut them to size . The size we use is 600mm Be carefull buy quality... alot are plastic....try and get the BOSCH ones from Autostop Part # BMN610-20 Went down to repco today but they didn't have the bosch ones. Went to super cheap auto and they did. They also cut them to legnth for me (passenger side only) and installed. All for $15. Super cheap always seems to be better than repco in my opinion. Thanks for the Bosch type Glenn. I now have silkly smooth and quiet window wipers again. Probably safe to drive in the rain at night now, could hardly see a thing in the rain last friday night. Cheers Edited May 4, 2008 by wild_weston Quote Share this post Link to post Share on other sites
