tune 0 Report post Posted May 10, 2008 Hey all, After the front and rear drivers side lower control arms for a 85" Coupe E30 323i Cheers Tim 0210666306 Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted May 10, 2008 Hey all, After the front and rear drivers side lower control arms for a 85" Coupe E30 323i Cheers Tim 0210666306 there is only 1 control arm on the drivers side and it is in the front, the one in the rear is a trailing arm and you might like to specify whether it is disc brake or drum brake and what size your diff is so that the half shafts are the right size. Quote Share this post Link to post Share on other sites
tune 0 Report post Posted May 10, 2008 there is only 1 control arm on the drivers side and it is in the front, the one in the rear is a trailing arm and you might like to specify whether it is disc brake or drum brake and what size your diff is so that the half shafts are the right size. Yeah was just looking at diagram of e30 suspension it is trailing arm at rear Disc brakes front and rear dunno diff size Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 10, 2008 have e30- parts 021433600 in papakura Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 10, 2008 Please link to aforementioned E30 suspension diagram! Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 10, 2008 labeled diagram.. http://www.speichers.com/e30_suspension.htm Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 10, 2008 have disc brake rear end sitting at home suitable for med case diff. and front subframe. you can have parts off it if you need. all in wellington Quote Share this post Link to post Share on other sites
