gmccormack
Wreaking
how more the bit between the rear lights on the red car?
and seats and door panels and that?
Panel between lights $40. All the seats,door cards, trim etc av cond $100.Lights $100 the set.
Greame
I'll take a passenger side brake cooling duct if you have one.
Cheers
How much for a gearbox & driveshaft ?
haha how much for a burnout???!!! hehe dollar challenge - smoke em up in your driveway and post us a vid of it!!!
cheers
Guest WAGON
how much for the passerger seat belt bit the "female bit" that you clip the belt into
and how much for the gauge cluster?
:ph34r:
$500 for box & driveshaft or $700 with everything needed for auto to manual conversion
:ph34r:
$20 for both but let me know which cluster you need as the prefacelift ones are switchable between 4 & 6 cylinder & some of the facelift ones are not & have a different number of lights on the SI board & different warning light configurations, some have clock instead of tach's etc,etc.
Greame
Cheers
Yeah Grant I've got one, I'll put it aside for you
Guest WAGON
oh and how much for the kidney grill and the clips that hold it in place at the top
and the hub caps
Edited by WAGON
can i take both gauge clusters and the seat belt thing
But which model car does the gauge cluster have to work with????? they don't all interchange.
and the hub caps
$30 for the kidney grill & are you serious....you actually want hub caps :unsure:
