DFL 0 Report post Posted May 24, 2008 I think that was well above 8000rpm I am thinking schrick cams, solid lifters, upgrade heads, chipping? Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted May 24, 2008 I'm thinking a lot more money than it's worth! Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted May 24, 2008 I'm thinking a lot more money than it's worth! Just fit a Honda S2000 engine Quote Share this post Link to post Share on other sites
Dyl 4 Report post Posted May 25, 2008 Mate... just put a POD filter on the 320. no worries Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted May 25, 2008 Just fit a Honda S2000 engine +1 Any Redtop K or F series motor will sound that like that crossed with an S14 Quote Share this post Link to post Share on other sites
Heresharry 0 Report post Posted May 25, 2008 I'm thinking a lot more money than it's worth! I second that.... too much money... Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted May 25, 2008 http://www.bmwinformation.com/model/3_series/e90.html You can buy it in the UK. The 320si is a special homologation version, built in order to qualify the car for the FIA World Touring Car Championship (WTCC). Released in 2006 and limited to 2,600 units, 500 units being sold in the UK. The 320si uses a modified 4 cylinder engine (N45) different to that in the standard 320i (N46). Modifications include an increased redline to 7,300 rpm, a shortened stroke (by 2 mm), an increased bore (1 mm) and higher compression ratio (11,0:1) over that of the standard 320i engine. The engine is mostly hand built and does not have Valvetronic, decreasing the number of moving parts. Acceleration from 0 to 62mph is in 8.1 seconds and acceleration in fouth gear from 50 to 75mph is in 7.7 seconds compared with a standard 320i which achieves 9.0 and 9.1 seconds respectively. Fourth gear acceleration is comparable to that of the 325i which achieves the 50 to 75mph sprint in 7.5 seconds. Quote Share this post Link to post Share on other sites
DFL 0 Report post Posted May 26, 2008 Nah the one I posted is actually E46 I6 320i racecar. Not the current E90 I4 WTCC car. http://www.ultimatecarpage.com/car/1348/BM...-320i-ETCC.html I6 sounds way better than I4 in my opinion. Is it difficlut to get a M52TU 320i to rev over 8000rpm? I mean only increase the rev without reaching that kind of hp is fine too. Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted May 26, 2008 oops my bad! Quote Share this post Link to post Share on other sites
