beemn 50 Report post Posted May 27, 2008 the lights behind the odometer no longer light up on the e36, i assume it just has a bulb behind it to light it up?...any special way the cluster needs to come out?????...or is it still round about the same as a dirty e30? thanks Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted May 27, 2008 http://logun.org/e36gauges.htm - the first few steps show you how to pull out the cluster, you just just twist and pull the bulb (it's probably green). Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 27, 2008 Just did an E36 compact today at work - two torx screws at the top, needed to remove steering wheel to get dash cluster out. Bulb holder is a beige one - need to replace the whole thing with one the same Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted May 27, 2008 Just did an E36 compact today at work - two torx screws at the top, needed to remove steering wheel to get dash cluster out. Bulb holder is a beige one - need to replace the whole thing with one the same thanks Grant, is it a special bulb...or wil repco have one???, and how hard to get an airbag wheel off? Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted May 27, 2008 Just did an E36 compact today at work - two torx screws at the top, needed to remove steering wheel to get dash cluster out. Bulb holder is a beige one - need to replace the whole thing with one the same I've removed instrument clusters from a compact, coupe and sedan - none required taking the steering wheel off, you just need to wiggle it out carefully but forcefully... Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted May 27, 2008 I've removed instrument clusters from a compact, coupe and sedan - none required taking the steering wheel off, you just need to wiggle it out carefully but forcefully... Sweet sounds a bit like me! Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted May 27, 2008 Not so sure on that carefully bit Milan? Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted May 28, 2008 Not so sure on that carefully bit Milan? haha Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted May 30, 2008 Just did an E36 compact today at work - two torx screws at the top, needed to remove steering wheel to get dash cluster out. Bulb holder is a beige one - need to replace the whole thing with one the same I replaced the entire unit (bulb and holder) in the past, but I vaguely remember someone mentioning that you could remove the bulb from the holder and replace it with a bulb of the same type available from Repco etc. Anyone know if that's true? Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted May 30, 2008 I replaced the bulbs on my dial Climate control and light switch with ones from Supercheap Auto. They're the same bulbs BMW use throughout the car for window switches etc so they're most likely the same in the gauge cluster too. Quote Share this post Link to post Share on other sites
