325_driver 422 Report post Posted June 2, 2008 Hey guys i think weve talked about this on another topic earlier but want a bit more info on it Aparantly the m20 manual boxes will fit the m50 also, from (e30 320 going to a e36 320) What about drive shaft? - Im assuming master cylinder wont - Clutch pedal? will it bolt up? - Shifter linkage probably wont ? - Cross member might be able to bolt up with a bit of alteration ? Would be good for some more advice on this Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 2, 2008 Hey guys i think weve talked about this on another topic earlier but want a bit more info on it Aparantly the m20 manual boxes will fit the m50 also, from (e30 320 going to a e36 320) What about drive shaft? - Im assuming master cylinder wont - Clutch pedal? will it bolt up? - Shifter linkage probably wont ? - Cross member might be able to bolt up with a bit of alteration ? Would be good for some more advice on this drive shaft and gearshifter mechs will be different length . have to modify cross member angles Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 2, 2008 drive shaft and gearshifter mechs will be different length . have to modify cross member angles master cylinder? youve got conversion parts aye? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 2, 2008 master cylinder? youve got conversion parts aye? might have Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 3, 2008 might have haha i know what that means, i will let you know if i need them if your going to give them lol Quote Share this post Link to post Share on other sites
