37 South 6 Report post Posted June 18, 2008 Oil seeping into one spark plug hole.Almost half full.Engine is a M42. Could this be a leaking rocker cover gasket and what is involved of fixing this ? Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted June 18, 2008 Oil seeping into one spark plug hole.Almost half full.Engine is a M42. Could this be a leaking rocker cover gasket and what is involved of fixing this ? Yes you'll need to replace the rocker cover gasket. Remove, clean and refit with new gasket set Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted June 19, 2008 How much do new gaskets go for? I probably should do this as well Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted June 19, 2008 How much do new gaskets go for? I probably should do this as well IIRC it's $100+ for the M50, for valve cover and spark plug gaskets. Just give the dealer a call, quite an easy job, just need a torque wrench and gasket sealant. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted June 19, 2008 How much do new gaskets go for? I probably should do this as well For an M42 about $100. You will need the rocker cover gasket, spark plug tube seals and rocker cover bolt seals. Rocker cover gasket set (includes spark plug tube seals) $ 42.50 + GST Rocker cover bolt seals 15 @ $4.13 + GST These prices are from BM Workshop in Grey Lynn Ph.3761250 I can supply them for less.... 10% discount to BS members Quote Share this post Link to post Share on other sites
