kleb1 0 Report post Posted June 21, 2008 hey im putting a m44 manual enigne into a e36 it was originaly a m40. can anyone help me with what wiring is going to be diferent and what i have to do thanks Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted June 21, 2008 hey im putting a m44 manual enigne into a e36 it was originaly a m40. can anyone help me with what wiring is going to be diferent and what i have to do thanks you will have issues with ews coded key stuff .if your car is an early e36 with no coded key Quote Share this post Link to post Share on other sites
kleb1 0 Report post Posted June 22, 2008 you will have issues with ews coded key stuff . if your car is an early e36 with no coded key i got the ews ignition with it. im thinking more with the plug on the fuse box will the m44 engine plug conect onto the m40 and go Quote Share this post Link to post Share on other sites
williams 0 Report post Posted June 22, 2008 i got the ews ignition with it. im thinking more with the plug on the fuse box will the m44 engine plug conect onto the m40 and go there is no ews wiring in ur car,u will have to have it wired in,the a/c fan wiring must also be modded(m44 electrical panel) Quote Share this post Link to post Share on other sites
kleb1 0 Report post Posted June 23, 2008 there is no ews wiring in ur car,u will have to have it wired in,the a/c fan wiring must also be modded(m44 electrical panel) i have wired in the ews and not using ac so not worried there. the ews seems to be geting the power it needed but it didnt start when i tried to turn it over. any ideas about what i could of done wrong. it was getting power owt of the ews to the starter motor so the ews must be working fine Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted June 27, 2008 Im not sure how EWS works, but ive heard it is part of the body? Anyway, you can chip your ECU, with a EWS disabled chip - if thats the problem. Quote Share this post Link to post Share on other sites
williams 0 Report post Posted June 29, 2008 ews-pin4(gn) changes to(sw/vi) pin 10 dme. there is a relay at steering coloum if it was a auto(sw/ge) for the auto-park Quote Share this post Link to post Share on other sites
kleb1 0 Report post Posted June 30, 2008 i got the m44 engine with manual and the ecu and loom was complete. ive wired it in n had ews put in but now wen i try to start it it doesnt turn over. i can here a clicking in the ecu so that is getting power and wen i test the block it is giving off 12 volts cna anyone help me why this wont b grounded? Quote Share this post Link to post Share on other sites
