User Name 19 Report post Posted August 7, 2008 Hi Guys Does anyone still have a manifold of the trubo 745i that i can use for my turbo project or does it not fit correctly Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 7, 2008 (edited) Hi Guys Does anyone still have a manifold of the trubo 745i that i can use for my turbo project or does it not fit correctly http://www.google.co.nz/search?hl=en&q...earch&meta= To be fair - it might work for all I know if you flip it upside down. The issue is that google would tell you that: a) it never came in RHD, so its highly unlikely there will be any 745i turbos here b ) it was rare anyway c) even if there were, the manifold didn't fit in the conventional manner in RHD Edited August 7, 2008 by CamB Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 7, 2008 Thanks for that ay, i would wunder if you could modify it tho, so maybe ill have to talk to a guy i know and see how much a firm can build one for me Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted August 7, 2008 (edited) its simple really, how much you want to spend? what material do you want to have? do you know what flange you want to use? wide range of $$.$300-2500. Edited August 7, 2008 by BM Weapon aka topcat Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 7, 2008 (edited) My main recommendation is that you make sure the mounting flange at the header end is strong - preferably 8mm or 10mm flange which you'd need to get cut/made (which will cost more in the short run but give less hassle in the long run). Edited August 7, 2008 by CamB Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted August 8, 2008 goto www.tcd.com or try www.666fabrication.com just buy one Quote Share this post Link to post Share on other sites
williams 0 Report post Posted August 8, 2008 the south african e23 745 came out in a 6 cylinder twincam, but the 745turbo had the single cam and used a kkk k26 turbo Quote Share this post Link to post Share on other sites
