E30-323ti
WTB: E30 325i Trailing arms
Does any one have a pair (that aren't bent Gus) that they would swap for some perfectly good 323i arms (disc brakes of course), failing that I will buy them.
I know you are all asking why?? because to the layman they are exactly the same.
Well I'll let you all know if my cunning plan works, which will be a great mod for those of you with high HP & Torque E30's that are scared of blowing alxes & CV's.
TIA
Hmm, I have a plan so cunning you could pin a tail on it and call it a weasel...
Guest Andrew
TIA
I'm pretty sure my 323 has (straight) 325 arms..
they DO look exactly the same when we had them all out the car before.. I wanna know!
Do you want to swap them for my 323 arms when you are down??
It is not a major difference ie. no performance/durability gain/loss by using either arm, just the 325 ones may be more suitable for my cunning plan, but won't know till I have some!!
There are 2 things that are different (both connected).
Or any E30 that has ABS will also be suitable.
I'd put mine in my old arms for you as I haven't put them in yet, cunning aye!!!
glenn whats the diff between the two? im curious as think i have a 318 left arm
Nothing you'd ever notice Gusto.
Don't want to let the cat out of the bag if it's got no legs, catch my drift.
no
WTF???
Are you practicing to stand up against your woman??? :P
Guest Andrew
well i'm not coming to welly anymore - had to drop out as the track day is that weekend. I may still come down though. I'll be in touch.
