ashok540 0 Report post Posted August 19, 2008 Any one know why my cruise control suddenly stopped working? I use it quite regularly, set at 60kmh to make sure I dont overspeed, it was working fine and suddenly the cuise light went off on the dash. Now I cant get it to turn on at all! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 19, 2008 Any one know why my cruise control suddenly stopped working? I use it quite regularly, set at 60kmh to make sure I dont overspeed, it was working fine and suddenly the cuise light went off on the dash. Now I cant get it to turn on at all! It could be one of many faults causing that Ashok. Needs to be scanned and checked. Anything else not working, or do you have any other warning lights on at the moment ??? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 19, 2008 Any one know why my cruise control suddenly stopped working? I use it quite regularly, set at 60kmh to make sure I dont overspeed, it was working fine and suddenly the cuise light went off on the dash. Now I cant get it to turn on at all! i have bits from a e38 740i if you want to try , might just be the button (you've worn it out) Quote Share this post Link to post Share on other sites
ashok540 0 Report post Posted August 19, 2008 It could be one of many faults causing that Ashok. Needs to be scanned and checked. Anything else not working, or do you have any other warning lights on at the moment ???My a/c switching not switching on when car is started after a long time is the only other problem. I will give you a call tomorrow and bring my car over. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 20, 2008 (edited) My a/c switching not switching on when car is started after a long time is the only other problem. I will give you a call tomorrow and bring my car over. Scan and check faults= (1) Brake light switch faulty causing cruise control not to work (2) Voltage drop inside ignition switch causing intermittent fault in climate air control unit Clear all fault codes, DME, ABS, EGS, Kombi (Combi). Road test and recheck All done Edited August 21, 2008 by botanymotorworx Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted August 21, 2008 ignition switches cause problems on e 39s...voltage drops.Didnt another 540 owner have similar probs recently(Huttey?) Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 21, 2008 ignition switches cause problems on e 39s...voltage drops.Didnt another 540 owner have similar probs recently(Huttey?) Its quite a common fault Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 21, 2008 Scan and check faults= (1) Brake light switch faulty causing cruise control not to work (2) Voltage drop inside ignition switch causing intermittent fault in climate air control unit Clear all fault codes, DME, ABS, EGS, Kombi Road test and recheck All done The proof of scanning - a must for modern vehicles Imagine the guesswork & time involved in diagnosing without Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted August 21, 2008 Clear all fault codes, DME, ABS, EGS, Kombi Road test and recheck What the hell is a Kombi road test?? I have visions of a Cheech & Chong road trip.... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 21, 2008 What the hell is a Kombi road test?? I have visions of a Cheech & Chong road trip.... Kombi (or Combi) = Instrument cluster Quote Share this post Link to post Share on other sites
ashok540 0 Report post Posted August 21, 2008 (edited) Scan and check faults= (1) Brake light switch faulty causing cruise control not to work (2) Voltage drop inside ignition switch causing intermittent fault in climate air control unit Clear all fault codes, DME, ABS, EGS, Kombi (Combi). Road test and recheck All done Thanks Glenn, everything working fine including my earlier problem of A/C swithing off automatically! Guess that was also due to the voltage drop. Edited August 21, 2008 by ashok540 Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted August 22, 2008 Kombi (or Combi) = Instrument cluster Ahhhh - I see. Cheech & Chong road trip sounds like much more fun! Quote Share this post Link to post Share on other sites
