_BRS_ 209 Report post Posted August 20, 2008 searched forum and couldnt find my answer Just after the star bolt size to remove the big chunky plastic bit from behind the bumper so i can put in my new indicators theres 6 star shaped bolts id rather buy the size i need than a whole set for $70 cheers blair Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 20, 2008 Not sure which ones you're on about. If you are just changing the lenses, unscrew them from the front - two phillips screws. If you are changing the entire units you need to remove the bumper - two very large torx-head (star) bolts under bumper and the whole bumper slides forward. If you mean the side repeaters, then they just have one phillips screw each. Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted August 20, 2008 (edited) im changing the complete units on the front hmm ok so thers just 2 underneath like the backbumper? guess i shuda hada look Edited August 20, 2008 by ---blair--- Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 20, 2008 I'm confused too ... however, a set of torx sockets isnt going overboard if you own a BMW. Buy a set of inhex & hex to cover yourself Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted August 20, 2008 I'm confused too ... however, a set of torx sockets isnt going overboard if you own a BMW. Buy a set of inhex & hex to cover yourself i have a set of torx sockets that i used on my manual conversionil sort it out tonight think i was trying to undo the wrong ones after taking the initial front bumper off Quote Share this post Link to post Share on other sites
