User Name 19 Report post Posted August 20, 2008 Hay Guys Does anyone have a pick or anything of the drivers side mount cause, ive being looking at other forums and they say i need to mod one or get one made up. Is this tru if so do you have a pic or does anyone have one that i can get for the w.e at not to much price cause i really need to do my swap this w.e otherwise another week of waiting Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted August 20, 2008 do what silver fox did with his e28 race car . check his posts Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted August 20, 2008 I got a 6mm steel bracket made up, you need to get it bent to fit the mounting points as they're not on the same plane, the top is back from the bottom, 30mm if I remember rightly. I used the E28 mounts as my template to get the shape and bolt hole position for the new part, and the E34 mounts as template for the engine holes, if that makes sense? You only need to do the drivers side one, there are 3 holes on the other side you can use. Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 20, 2008 Thanks for that guys, im sure i can get something made up Cheers Quote Share this post Link to post Share on other sites
