User Name
e32 - e28 engine swap
Hay Guys
Does anyone have a pick or anything of the drivers side mount cause, ive being looking at other forums and they say i need to mod one or get one made up.
Is this tru if so do you have a pic or does anyone have one that i can get for the w.e at not to much price cause i really need to do my swap this w.e
otherwise another week of waiting
do what silver fox did with his e28 race car .
check his posts
I got a 6mm steel bracket made up, you need to get it bent to fit the mounting points as they're not on the same plane, the top is back from the bottom, 30mm if I remember rightly. I used the E28 mounts as my template to get the shape and bolt hole position for the new part, and the E34 mounts as template for the engine holes, if that makes sense? You only need to do the drivers side one, there are 3 holes on the other side you can use.
Thanks for that guys, im sure i can get something made up
