E30stz
Guide bolts for E30 Calipers
ANyone know what size these are, I thought they were 8mm allen bolts but they do not seem to be the correct ones. Trial and error isnt working to well and dont want to strip them.
Did mine a few days ago using a 7mm, try that
I assume your talking about the bolts with the internal hex head? if so try an male torx key. cant remember the size though sorry. Theres a few other little bolts that use them on an e30 so buying a set isnt a complete waste of time
Note: There is 2 different calipers for the E30, Ate and Girling. I'm not sure if both made it over here. I think what I mentioned up there applies to the Ate caliper, i'm not familar with the Girling ones
Edited by Mike
