matt45 1 Report post Posted August 30, 2008 hi all, Stock E36 Headlights with condensation what is the best way too fix and prevent this problem?.... or is it a simple case of just leaving them to dry out? Thanks in advance for your help. Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted August 30, 2008 Turn your headlights on and go for a drive. The heat from the bulbs will generally dry them out. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted August 30, 2008 Surely if it happens often you can seal the plastic front to the light unit? Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted August 31, 2008 On a dry day, remove the cover for the bulb in the engine bay as if you are changing a bulb, then turn the lights on until the condensations are gone. But that said, they shouldn't really fog up inside to start with. Maybe the seals are "fogged" ? Quote Share this post Link to post Share on other sites
greenday-rulz21 4 Report post Posted August 31, 2008 This has been annoying me for the last 4 months. Only happens in the left hand side headlight, luckily its not in both. But opened up the back, got a hairdryer and completely dried it so you couldn't see anymore condensation, but it came back the next day! AHH. Also happens with the left hand side front indicator. Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted August 31, 2008 hehe, I was looking for a solution this today aswell for my touring! Best I can find on the web is to remove the covers on the top, turn on the lights and go for a drive. If you decide to just leave your lights on whilst your at home, dont leave it too long cause you'll end up with a flat battery ! Ultimately though, the water must either be getting in or not being allowed to get out of it. Apparantly there is a hole in the e39 headlights that can get blocked but Ill be buggered if I can find it. Quote Share this post Link to post Share on other sites
